Hey folks...main cabin AC in my 38xx stopped working. Seems to be the thermostat control...initially you could turn it counterclockwise and the heat cycle and compressor would come on, but you couldn't turn it far enough clockwise for the AC to come on. After a bit, once you turn it on, the heat comes on and you can't turn it off. Compressor runs, water flow looks fine...sounds like the thermostat, correct?
I pulled the panel off, and saw a sticker over a hole in the thermostat (said "Don't mess with this until you call us"...however, the 800 number rang at an insurance company now...LOL), so I pulled the sticker off and tried turning the calibration screw fully clockwise and counterclockwise...no dice.
Google yielded the mfg for that part number, but I can't find a supplier. HOWEVER...I suspect that it's no magical thermostat and there are probably plenty that would work with the same wiring. I don't want to replace the whole AC/heat unit, the rest of it seems to work quite well even though it's old. Perhaps there's a newer control panel that would work with the old AC/heat unit?
I'll also bet there are two of the pictured wires that I could simply jumper to bypass the thermostat and turn the AC on 100% of the time (on hot NC afternoons, it runs constantly anyway).
I can't be the first person who's run into this...any suggestions much appreciated.
TIA!
TIA!
