First off, I'm going through one of those phases when a lot of stuff I own is breaking. Ice maker bit the dust, two lawn sprinkler heads cracked, radio in my trusty SLK stopped working, lost an alternator on the boat........the list is longer but you get the idea. I went down to the boat a couple days back to piddle around with some stuff and went to use the head. No vacu flush pump. Checked the circuit breaker and it was fine. All other a/c connected to shore power one working. So I pulled up the carpeting (my wife made a carpet to cover the original 20 year old factory one) opened the hatches and started checking wiring. No voltage at the pump. I kept hitting the flush lever to see if it would activate the pump but nothing. As you know, when you do this without vacuum, the head will spray a fair amount (like a mini volcano).
I started tracing wires and found the one that goes from the pump to.............the little switch next to the head that says 'sleep'. Apparently someone on the 4th decided to turn it to sleep mode.' So basically after 20 mins of swearing and pulling up carpeting, the solution was right under my nose. Lesson learned.
