47 anchor light-gctid816017
    Has anyone replaced there anchor bulb with a LED? What part # did you use.
    Thanks Dave
    I recall there was a great post a year or 2 ago on this very subject that had photos of bulb base, which bulb to buy and other information. I can not find the post and also need the information.
    Started boating 1965
      I put a SeaDog line LED 24" light on my 4788 as an anchor light. It is quite bright and sucks very little power. It also hinges down for winter shortage.
      Here is the link. http://www.sea-dog.com/groups/98-led...l-around-light
      Cheers
      Carlo
        If you know what style bulb you have currently, its pretty easy. I used these guys when I had my 3055 and also replaced the anchor light in my Carver. The LEDs are so much brighter than the old style. You'll see the difference right away especially if your in an anchorage with other boats. As Carlo says they also use very little power. https://www.superbrightleds.com/cat/boat-rv-bulbs/
        Doug
        Hanging Loose
        98 Carver 350 Mariner
        2013-
        KRUSTY KRAB
        2001 305
        5.7 BII
        2006-2013
