Cummins Database
This is a sticky topic.
    Cummins Database
    Hi Everyone,
    This database is for Cummins engine information: part numbers, interchange part numbers, specifications, detailed procedures, etc. Please do not post questions or issues specific to your boat. It's OK to post feedback on data that should be included here. Keep in mind, that once someone posts the data, your feedback post may be deleted to keep the database clean. Thanks in advance.
    2013 Boston Whaler 130 SS
    Those of you with Cummins engines can set up a free account at Cummins Quick Serve. You will need the engine serial numbers to do it. Quick Serve provides access to parts catalogs, specs, etc: https://qsol.cummins.com/info/index.html.
      On most of our boats it is hard to access the fuel filter on the port engine and the oil filter on the starboard engine. To simplify servicing the filters can be relocated toward the center line of the boat. Cummins makes the parts necessary to relocate both filters, but many Cummins parts providers do not know what to look for. Seaboard Marine (sbmar.com) is familiar with filter relocation and can provide kits with all the parts and hoses needed.
      Here is a photo of the Oil filter relocation kit installed on a 4BTA engine. The 6BTA installation is the same:
ID:	392496Click image for larger version
        All Cummins 6-series marine engines have a one zinc in the heat exchanger. Raw water after-cooled engines have two zincs in the aftercooler.
        Zinc model number: E2
        Zinc size: 1/2" NPT thread, 5/8" pencil zinc
          Tony Athens at Seaboard Marine has a very helpful page full of tips on Cummins engines, gearboxes, props, etc:
          https://www.sbmar.com/tonys-tips/
            Cummins engines oil pressure sender:
            Sierra p/n OP24891, Dual Station Oil Pressure Sender - 80 PSI
            It is available from a number of places. Fisheries Supply usually has them in stock under Sku# 92208
              Oil Filter for Cummins B https://www.cumminsfiltration.com/si...s/MB9-02-1.pdf
              The LF 3894 is an upgrade to cheaper cellulose or glass fibre filters under a proprietary name StrataPore, which is a finer, lower micron filter.
                Here from a flo-scan test:
                Bayliner 3988 Cummins 270hp. Flat water, 2/3’s fuel, full water, normal gear load.
                RPM SOG GPH MPG Range
                1000 7.1 kts. 3.00 2.37 639
                1100 7.9 kts 4.00 1.97 533
                1200 8.4 kts 4.80 1.75 472
                1300 8.7 kts 5.20 1.67 451
                1400 9.1 kts 5.80 1.57 423
                1500 9.5 kts 6.20 1.53 413
                1600 10.0kts 7.60 1.31 355
                1700 10.5kts 9.00 1.17 315
                1800 11.8kts 9.80 1.20 325
                1900 13.5kts 12.00 1.12 303
                2000 14.5kts 13.00 1.11 301
                2100 16.1kts 15.00 1.07 290
                2200 17.6kts 17.00 1.03 279
                2300 19.6kts 20.00 0.98 264
                2400 20.7kts 22.40 0.92 249
                2500 22.1kts 25.00 0.88 239
                2600 23.0kts 30.00 0.76 207
                  #1 Cummins OEM Sherwood 1730 Seawater Pumps
                  02-19-2019, 03:47 PM
                  One of the Sherwood pumps on my 4788 is leaking at the shaft seal, so rather than blindly purchasing a new Seamax SMX1730 as many have recommended on this and other forums I decided to do some research. I had a lengthy conversation with a technical service rep at Penaire, the company who owns Sherwood pumps and he provided the following history.
                  Starting in the 1990's Sherwood 1730's were standard equipment on many Caterpillar and Cummins marine engine packages. Eventually Sherwood recieved feedback that there were problems with bearing and seal reliability as well as occaisional housing casting issues. They told Cat and Cummins about this and informed them that improvements would be made. Both companys said " The pumps are lasting past the warranty period, dont't improve them, we want to sell parts. Since they were the major consumers of these pumps nothing changed untill around 2006 when Sherwood upgraded the pumps anyway with better castings and shaft as well as bearings that were pressed on instead of being secured with snap rings and they also upgraded the mechanical seals. Since then reliablity has significantly improved.
                  I was a Service Rep for a major machinery manufacturer for over 30 years and I have experienced first hand what this gentleman told me.
                  These improvements made the stock Sherwood pumps essentialy identical to the Seamax SMX1730 which eveyone loves with one important difference.
                  I can purchase Sherwood 1730C pumps online for $486.00 at places like Marine Pump Direct whereas the Seamax SMX 1730 is $750.00 ... a $264.00 difference.
                  I'm going to purchase a new Sherwood and buy 100 gallons of diesel with the money I saved.
                  On second thought... I will dismantle my pump and if the bearings are retained by snap rings I'll purchase a new pump.
                  If the bearings are pressed on I'll buy bearings, seals and an impeller kit and save a few hundred dollars more.
                  2001 Bayliner 4788
                  Underhulls
                  Bow & Stern Thrusters
                  330 Cummins
                  Langley British Columbia
