Hello brain trust!!
Had another crappy situation. Thought my water tank was only half full and then bam, light goes on.
Wanted to look at gauges for it so that I can see where it is at. Then I see on the water gauge on the front of the lower helm ( One you press the button and it shows you the level the water tank is at) ... there is a spot to put a second button?? Would it work to have a sender put in the tank and put the wires to that gauge?
Thoughts?
Thoughts?
