Rain Water in Bilges on 4087-gctid814855
    Over the winter (dry in FL) I've solved a number of issues on my 4087 Bayliner. This spring I'm getting excessive amounts of rain (fresh) water in my forward bilge (bottom of steps forward) and some in my engine bilge! At one time the condensate sump was not working and it ran over but I fixed that problem . Any ideas where the water is entering? I see no leaks in cabins, windows or ports . Anchor locker is dry. I've vacuumed out 3 gallons or more at a time (bilge Pump sits high). Need to go over during hard rain but it's hard to get there during afternoon storms.
    1999 4087 with twin Cummins 270HP
    Custom Hardtop over Flybridge
    I just solved this mystery on my boat. I caulked the top edge of the rub rail. It was caulked at one point but over time it deteriorated. Both bulges are now dry for the most part. It's surprising how much rail water gets in there.
    "Martini's Law" SOLD
    Nova Scotia, Canada
      Exactly, I have a 3788, same vintage and I had a similar problem. The water comes in from the rubrail. It's very tough to track down as in some areas you have no access. The solution, as suggested, reseal the top and bottom of your rubrail.
      2019 Cobia 240 CC
      2006 Boston Whaler 13 Sport
      1985 3270/Hino 135s (Sold)
      Vero Beach, Fl.
        Thanks for the suggestion. I noticed a little coming from that joint where I could get access. I'll try caulk next. What product did you use?
          I used 3M Marine clear silicone.
          Nova Scotia, Canada
            As a side note, you may want to also check your hot water heater and ensure all connections and tank are sound. I had the same issue with what I thought was rain water and it turned out to be a leaky hot water tank.
            ___________________
            1998 Bayliner 4087
            Twin 270 Cummins
            Powered by Awesome
              I have the same problem and it also turned out to be the hot water heater.
              It's very surprising how much water was leaking.
