Pilothouse upgrade-gctid814209
YES, I replaced the carpet with Teak and Holly as well as the new Captain's Chair myself. I must throw a big Thanks to John Higgins for his advice as to what I was going to run into and mounting solutions for the Pedestal. It was a task! I removed the bench components and reinstalled them after they were redone.
Carlo
Carlo, your work looks amazing as usual! I really would like to bolt my helm chair down but we board a lot through the port side PH door and bringing stuff in/out all the time it's really nice to move it out of the way. Also, I've talked with John about how difficult it is to bolt down
I like the cream colored vinyl on the starboard side area too. I just replaced mine with same color (blue) but really wanted it to match the cream color but got over ruled by the design committee. I'm construction crew so I lost...How is that color with glare on sunny days? That was one of my concerns with going to a lighter color.
Derek
1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
Really really nice! Question: it looks like you have made the vinyl panels under the helm dash removable. Does that give you access underneath the helm?
MV Kia Orana
Currently Enjoying the PNW
Hi Guys
Thanks for the compliments. I will try to answer several questions raised below.
The total cost to recover the benches was $1,200 Canadian taxes included (that's about $50.00 American!). I made new bottom plywood pieces as the original ones had holes with leather straps which were supposed to provide extra comfort. The straps stretched which actually made it uncomfortable. we also added 1/2 inch of extra foam material over the old foam .Removal was no big deal once we figured out how the pieces were fastened.
I have not had the boat out yet on a sunny day so I don't know how the light colour will perform.
I used a urethane Gloss floor varnish 5 coats.
The vinyl panels on the face of the lower part of the console are just a pad over the fiberglass.
I used 1/4" 4 X 8 sheets of Teak and Maple sole. It runs about $350.00 a sheet here. It took two sheets
Cheers
Carlo
The floor is gorgeous! We have a urethane finish on our teak and holly floor. What are you going to use to clean it and maintain it? I was advised by the PO that they used water/vinegar and someone on BOC also uses that. We have a new to us boat, so that is why I am asking. Thanks!
1991 57 Widebody Tollycraft "Solana"
Formerly:
4788
3988
2858
Ladysmith, BC
Michelle
