Due to a leaking fitting at the T to my ice maker I have spent the last couple nights disassembling the insides of my wetbar and removing all the remaining carpet from the floor and wall (previous owner removed most of the carpet) so the area can dry. I see a plywood panel but it appears to go from the bulkhead all the way up to the lower helm. There has been discussion of an access panel under here that enables you to access the blower fans and other wires. Do I need to cut into mine? There are long screws in the board that secure the panel to the boat but not sure what they are attached to.
Thanks in advance.
Thanks in advance.
