PLEASE HELP SUPPORT OUR SITE
Thanks!!!!
Bayliner 3818 salon ceiling light replacement-gctid813318
Admiral is asking for a replacement for the ceiling lights over the salon table. Looking for something warm and fitting of the age of the boat. Wanted regular bulb so I can replace them with warm LED's (2700k)
Cant seem to find any online.
Any thoughts or suggestions?
Craig
Nanaimo bc
1987 bayliner 3818
w/ 175 Hinos no Genny, but solar to run everything!
10ft Livingston with centre console and 15hp on davits / winch
Hi, I changed mine a few years ago with LED's. They are a "touch" light that turn on by touching them (so no switch required) They also fitted perfectly into the brass rings that the original lights were in.
The only downside is that the LED's are a very white light but light up the whole cabin. The upside is that they (when touched twice) glow red which is brilliant for travelling at night.
How thick is that light? For some reason the factory light in my second stateroom gets hit by the door to the bathroom when you open it. It this light is a little thinner it would make a great replacement. The web link does not state any dimensions- look like about 6" in diameter- is it less then 1/2" in thickness?
If the 3818 has the same two salon lights as my 3218, I chose to buy LED festoon lighting on ebay that fit in the slots of the old lighting.
I didn't see anything wrong with the existing fixtures and head room was very important. If I get up from the couch even with the old light fixtures I can bang my head.
If you consider this route measure the existing festoon bulbs and you should be able to find a close if not right on replacement.
They have bright and dim bulbs.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
The lights are about 1 1/2 inches thick. As they are over the salon table it does not matter to be if they are thicker. Think I could go as thick as 6".
Craig
Nanaimo bc
1987 bayliner 3818
Ok, it was just a thought. I just looked at a few 3818s for sale on youtube and they had the same square low profile fixtures as my 3218 about 1 1/2 thick.
Dan
Claudia V. III
1988 - 3218
Gas Drives
I should have mentioned that all the old fluorescent lighting along the windows and the 3 I have in the galley I replaced with LED light fixtures that have two settings high and dim. They were bout 6 inches shorter but are 3 times as bright.
Dan
Claudia V. III
1988 - 3218
Gas Drives
I still have a few fixtures to go, including the navigation lights. Yesterday I installed LED's in the 12v panel to replace the burned out indicator lights.
Edmonds Yacht Club (Commodore 1993) 1988 3818 "GLAUBEN”
I took the original square ones down, cut a piece of 1" thick teak 10" x 16" and mounted two brass Victory halogen 5" dome lights on the teak plank. I don't like LED light. These dome lights also have rotary dimmers and have had the same bulbs in them since 2007.
I got this picture off of the Victory site and it does not have the dimmer, just the toggle.
The Admiral commented, even after I replaced the incandescent bulbs with led, about the round master stateroom ceiling light was that it was "crap". So, trying to be the attentive husband, I installed one of these in place of the venerable old round light with one of these:
When she turned it on she immediately said it was too bright. So I showed her how to dim it to her liking by touching and got a "that's better" which is about as good as it gets.
If the blue option was red I'd already have one in the salon.
