Oil sender unit part number eh700t-gctid813148
If its the oil sender for the gage and not the buzzer than you must have a sender that is compatible with two oil pressure gages - upper and lower.
The dual station sender will have the correct resistance for you gages to read correctly.
I have used duel stations senders from various brands and manufacturers and they all worked fine.
