Compass on Bayliner 3988-gctid812557
    Good morning,
    Anybody would know the model and size of the compass on a 3988 of 1995.
    I would like to repair mine (no oil in it) but I forgot to look at the model number last weekend
    Eric
    Bayliner 3988 1995 Hino 250hp
    There's a special mineral oil that is used. It isn't specific to any model number. Just pour it in and see if the seal holds. Often the oil expands in the sun and pushes out without damaging the seal.
      They came with a Danforth Constellation which are no longer made. There is one repair facility you can google online.
      I replaced mine with a slightly smaller Richie compass and used the Danforth retaining ring epoxied to the Richie to retain
      the look and cover the cutout.
      "Adios Dinero"
      Photo Credit: Whiskywizard
        Thanks for the info
        Eric
          Here's a compass adjusting and repair business: http://www.islandmarineinst.com/
          2013 Boston Whaler 130 SS
          Isla Verde, PR
            Isopar L is the fluid. West Marine has it.
              Replacing fluid is fine assuming that the 20 year old flexible diaphragm in the bottom is still in good shape.
              In most units of this age it too will need replacing and parts are not easy to find.
              This is approaching replacement values with shipping etc.
              "Adios Dinero"
                Original Danforth Constellation at lower helm, still working fine
                New Richie Compass with original Constellation trim ring on flybridge, sorry about the camera angle. And, yes, they both read the same, the boat was swinging on her lines.
                "Adios Dinero"
                  My lower helm one too is in excellent condition, the upper one was half filled with fluid but it is in great condition too because this is a fresh water boat with enclosure and a helm's cover.
                  Eric
                    I had a local guy try a repair on my old Danforth's (circa 2000) which was complicated by an old card inside not being compatible with Southern Hemisphere which meant trying to rebalance the card. It worked for a month or so, then the bubble started to appear and get larger. In other words the oil was slowly leaking out.
                    The organisation that I think Gary was referring to is Viking Optics. They bought up all the spares etc when Danforth closed. They had a repair deal and I had one of mine rebuilt. But as always, it depends on how much you want to pay. The guys name back then was Howard Maglathlin. Email [email protected].
                    Hope it helps. Cheers
                    John H
                    Brisbane QLD Aust
                    "Harbor-nating"
                    2000 - 4788/Cummins 370's
