I have a 1988 45 PH which still has the original Raymarine radar that has become useless. I also am using an analog C120 chart plotter and I would like to be able to use it for my radar display. I plan on finding a good condition used array. Does anyone have info on how the cable is routed to the PH and how difficult it would be to to replace?
Replacing my radar-gctid812253
Hi drwayno,
The cable, that was in my 4588, ran from the port side of the dash , under the port door threshold and under the adjacent seat. In the back of the inside of the seat, there is a panel that opens the wall up , exposing the wiring. The routing continues towards the stern a couple feet and turns upward, toward the bridge. From there there is an opening in the port-most wall under the bridge dash. As I remember, there is an internal wall with an opening that you can reach into to feel the wires, though it's difficult to get your head into a position to physically see it. That is where the cable runs through. From there, the wires head along the inner wall of the bridge surround towards the radar arch where it routes up to the radar array. There are couple of ties or cable clamps inside the walls, but they can be removed and replaced as needed to remove the cable.
The one thing I remember is inside the wall between in the bridge, there is wall (as described above) that shields a hole in what appears to be the floor level of the bridge that is just a bit larger than the existing wiring. As such, it may tough to get new wires through without removing the old or drilling a new hole, which can be a bugger, too , as the area is hard to reach, let alone being able to get a drill into.
I hope this helps. Good luck it's your routing...
~BJ
OMEGA
5788
BJ
OMEGA
5788
Setting up and using the Quantum is really easy!
Derek
1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
