I have my boat out of the water right now to paint the bottom and other chores.
I think my boat would be the same as other 1986 3870's, but the way my 4 tabs work seems strange to me.
I am rebedding all the transom bolts screws etc and pulled down on the outside port tab and when I pulled it down the port inside tab went up.
Tried the same excercise on the starboard tabs with same result...... can this be right?
I usually run at 7 knots, so assume I am not using any tab when I put the tabs up with the controller, but obviously only the outside tabs are up.
What am I missing here?
