What did was vacuume the heat coils to get rid of the dust. I didn't take the unit out of the cabinet, just removed the front cover and cleaned out the dust. Apparently that was enough of a shock to give it a heart attack! The box gets cold enough for condensation to freeze in the back upper corner but not in the bin. The harvester will cycle with a little encouragement to rotate, and the tray fills with water. I tried turning the colder/warmer adjustment to no avail. It turned, but no significant change was evident. Yes, the unit is running, and was doing just fine until I tried to clean the cooling fins.
I'm sure its the 1988 original to the boat, I'm reluctant to start throwing parts at it, and the Admiral isn't going to approve a new unit at Uline pricing. Fact is, neither am I.
Any insight out there as to what may be going on? I suspect it's some circuit board or sensor and its laughing at me.....
