Would any radiator coolant hose work for the antifreeze side of the hino Diesel engines? I dug through some of the radiator hoses at autozone and I found 2 hoses that have the right diameter and bends to replace the 2 large diameter hoses at the manicooler and the hose from the oil cooler to block. The 2 hoses will make 6 peices (3 per engine).
This is assuming the hoses are ok? $40 total was worth buying to test fit. Part numbers below:
B70797
E72257
B70797
E72257
