We previously had a Shurflo extreme 5.7 fresh water pump in our 4788. I loved the pump--superbly quiet and worked great. It pumped into an accumulator tank and you truly didn't hear the thing 95% of the time it was running--only when using two or more plumbing fixtures at once could you hear it hum quietly.
Last year it died. We replaced with the shurflo replacement that is NOT a variable speed pump. It is VERY loud every time it cycles on.
Has anyone found a great freshwater pump that is QUIET? Variable speed preferred but primary objective is quiet operation.
