Galley puck lights not working... when we put a test light to switches I have both ground and hot wire that is hot. Question is can somebody tell me where to find the fuseblock location for galley switches/lights?!?? Thanks for the help stay safe and float on friends!
Help wiring help-gctid809695
Spent last night trying to get my starboard nav light working. I checked for power with a voltmeter and it was showing good. I put a good bulb in and it still wouldn't light up. Started playing with the 2 contacts on the fixture for the bulb and bent them a little bit for better contact and it lit right up. Try a new bulb first and then I'm +1 on the fixture as well. Could be bad contacts.
2001 Bayliner Ciera 2455
"KidsTuition" post=811376 wrote:
Have all lights in cabin working except 3 lights over the table. No power to these wires. Thanks for the input as well!!
Derek
1989 Bayliner 3888 175 Hino’s - Mahal
(Past)1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
(a) both poles have +12 ==> Ground connection is broken (This requires switch to be ON; try the switch in both positions)
(b) one pole +12, other gnd ==> Bulb or socket is bad
(c) both poles no voltage ==> switch or connection from switch is broken
[email protected]
[email protected]
What kind of bulbs are you guys using? If you change over to led bulbs they can only go in one way. I learned this changing out all the festoon lighting to LEDs. All lead wires were hot, good ground but bulbs were dead. I had to turn the ones that wouldn't light up 180 degrees.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
