EH 700 BLOCK DRAIN-gctid809604
  • Johnny_Vintage
    Shop Vac. That's the ticket. Thanks, I have small one on board and four 5 gallon pails too.
  • smitty477
    "Do you guys just drain it into the bilge and pump it out later?"
    I put a longer slightly larger ID hose (clear) around the existing hose and pull it out with a clean wetvac.
    Often I would then use that coolant to winterize the raw water side of the engines.
    +1 to Jim
  • Jim_Gandee
    Johnny, if you're referring to draining the coolant the head pressure will allow some uphill run of the drain line. I drain it into a bucket/vacuum contaInner (my oil sucker). I never allow it to drain into the bilges as it makes a mess and is a PITA to clean up.
  • Johnny_Vintage
    started a topic EH 700 BLOCK DRAIN-gctid809604
    On these Hinos, The block drain has a hose going into the bilge. There is no way to put a collecting pan under there. Do you guys just drain it into the bilge and pump it out later?
