PLEASE HELP SUPPORT OUR SITE
I use a 4:1 boom vang.... to hoist my c12, off a 6" cleat I mounted on the hard top... It allows plenty of room to walk under for port or stbd access... no boat/top issues in 5 yrs with this setup Winch would work too... but for me... it was where to mount the winch, how to get enough wire there to run it.. where/how to mount remote controls.. stow em... and for me.. how to cover it all and make it look properly installed...
Dink, weaver hard mount arms fore and aft... fully equipped with either a 25hp or some times 40 hp both two strokes... 25 is approx 100 lbs.. 40 is approx 140lbs... 6 gallon can, anchor, line and pumps and a couple of life vest in vee compartment... ready to go as fast as you can un loop that line and drop it... minutes...
Im 6ft plus and agile... not an issue for me (yet)... my 130Lb gf struggles with it... but prevails... how ever she is tenacious... in many ways.... maybe I should get her a harkin 15 :1 dingy vang for Christmas....
a caution : that line came loose one day ( Probably got left unsecured by the a... captain... 1st mate ??? I jdo know it wasn't the admiral, she don't make mistakes like that) and leaving the fuel dock I reversed on it... knocked loose a trim tab... made me get out my hookah rig clear the prop and remove that loose tab.... always nice to have an audience.. LOL.
I have a manual winch system as well as an electric winch on my boat currently to pull up my 11' Rib, 20hp 4 stroke and helm.
Original system was two double blocks that I clipped into a line that was around two of my hard top stanchions. I then put the tailing end around a small sailboat winch that is mounted to my rail. Made it easy to control the release.
Now I have a 12v winch that mounts to the underside of the hardtop utilizing the weaver winch mount (had plate made).
Sean 1987 3870 Crimson Pride II Past Commodore Mukilteo Yacht Club MMSI: 338080226
I have a winch mounted down in the rear above the rudder tie-bar and cable routes out through the transom on a pulley. Being out of the weather has meant that it has lasted where a lot of them that get mounted on underside of the top get a regular misting of salt. Prior owner had one mounted on the transom externally and was a corroded up mess. That is where I got the pulley idea - I needed the cable to pull horizontally for the davit I had but didn't want to put another winch out to sacrifice to the salt gods.
I didn't opt for the wireless control so I have a pendant that I stow inside of a deckplate in the cockpit side of the transom.
Wasn't when I got the boat. I have since added a hardtop. The cable routes inside the transom similar to how some rigging is done in sail boat masts. The pulley I used is intended for a mast. Even if enclosure was there the cable come out below it.
I have seen a number of winches mounted under the rear brow of boats without a hardtop.
I have a 10' Livingston on weaver davits. It's very hard to do solo, and I lift weights. So I use pulleys now. A rope tied to the upper rail runs down to a pulley on the Livingston and then back to a pulley on the upper rail. Makes it very easy.
Esteban
Huntington Beach, California
2018 Element 16
