Any of you guys with 32's try to remedy the list towards the starboard side, and do you recall how much weight it took to level the boat out?
adding ballast to a 32XX-gctid808761
I've moved stuff but most everything in there is nailed down by Bayliner, thrown away stuff and now have added weight. Its not so much when I'm underway but just sitting in the slip it looks funny. I added 4 sand tubes which equal one fat guy. 280lbs.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
The list on a Bayliner is usually a result of which side the galley is on, galley being the low side.
If the air conditioning is installed on the same side, there will be a list unless a counter weight is installed.
I have that long couch on the galley side ( port side). I wonder if Bayliner put a couch full of people in their calculations? Its usually just the wife and I at the boat and parked it always looks like its got two flat tires on the right side. Not anymore. Underneath the mattress in the aft cabin there is that one long locker and its now put to good use .Just wondered if anyone knew how much weight they put in to correct the list.
Dan
Claudia V. III
1988 - 3218
Gas Drives
Not sure on the weight, but you might consider a wake board boat ballast tank so you end up with extra water at the same time...something like the below
https://www.wakemakers.com/wakeboard...89YRoCL4Hw_wcB
Mark
USCG OUPV
1990 4588
Carlsbad, CA
I'm not sure if the 32xx has space for this, but a friend added an additional potable water tank to his boat. He fill it enough to take care of the list. If he's going to go for s number if days at anchor he fills it completely. The it lists slightly to the opposite side until he uses the water.
2013 Boston Whaler 130 SS
Isla Verde, PR
"mmichellich" post=808854 wrote:
Putting ballast in a planing or semi planning hull makes no sense. Add something that is useful.
Doug
Water weighs 8.33 lbs per gallon for fresh water. Sea water weighs slightly more at 8.55 lbs per gallon. #2 diesel weighs 7.15 lbs per gallon. Gasoline is the light weight at 6.07 lbs per gallon.
Newport, Oregon
South Beach Marina
