Replacing a propane tank-gctid808324
    Cheers has a horizontal propane tank and I may have to replace it (it's a bit rusty). Has anyone replaced a horizontal tank with a BBQ grill-type tank? Would there be safety issues? Different fittings?
    I priced new tanks; the horizontal tanks are around $200 and the BBQ are around $60 for the same capacity. It would be nice to save the money if there are no safety issues.
    Dick
    Cheers
    Oceanside
    1987 3218 w/ 150 Hinos
    You can't lay a BBQ tank on it's side -- it's meant to sit upright. So as long as you do that and properly secure it, you can use one of those.
    Terry
      Thanks Terry. The tank is located under the flybridge console and there should be enough room to mount a BBQ-style tank in its normal orientation.
      Dick
      Cheers
      Oceanside
        There are propane tanks that are designed for horizontal mounting, expensive though.
          I traded tanks on Mr. Darcy. Got rid of the very heavy horizontal tank and replaced it with an upright BBQ style. A couple of ss eye bolts with acorn style nuts and fender washer on the outside ends, fender washers and l/w with nuts on inside and a racheting tie down strap keeps it secure.
          Greg
          Newport, Oregon
          South Beach Marina
            Doing the same here in France where it is nigh on impossible to get the old tank filled. We have domestic and outdoor 6kg bottles which, by unbolting the handles, can slide neatly into the space, and I am fitting a simple base with tie down strap.
            A lifetime of racing everything from dinghies to world girdlers, but one of those lucky people who just love being afloat. So .... when the body doesn't work like before, it doesn't mean staying ashore.
            Blustery Day
            Bayliner 3288 Motoryacht, 1991.
            Twin Hino 150hp diesels.
            Purchased 23 February 2017
              I had my 20 year old horizontal tank re-certified, its only issue the gauge always reads full. I was refused a fill at one place before I got it re-done, went back an hour later somonelse re-filled it no problem.
              Some where on the web I found information about horizontal tanks not having to be re-certified, printed it up and have it on the boat, but not on the boat so can't share it. Yes I can, http://commutercruiser.com/propane-t...on-regulations, read forth paragraph.
              Machog
              1996 4087 Lazy Days
              2011 Porsche Cayman
              2010 Lexus IS 250C
              2008 Honda Ridgeline
                Two 10 pound BBQ tanks are much better than any 20 pound arrangement as long as they are properly secured.
                  I got tired of argueing with the propane filling station every time I tried to refill the horizontal tank. Easier to get a BBQ style. Will be mounting it next week.
                  Jim
                  1988 3270 With 135 Hinos
                    Has anyone had comments from marine surveyors about the placement of tanks on the upper bridge? I just had a survey and he was saying the tank should be contained in a vented overboard compartment. He wants me to drill and use thru hulls on the upper walls to vent space under upper helm. Says any leak from up there will flow down the stairs and collect in the cockpit and engine compartment.
                    Any comments about this?
                    Terry
                    Terry
                    Br$keAweigh
                    1987 3270
                    H/P - Powell River, B.C.
                      Sounds like BS to me. So how is a vertical tank different from a horizontal tank in terms of venting.?
                      Jim
                        Jim
                        He did not say this for horizontal tank only. Does not matter horizontal or standard vertical tank- both supposed to be in a compartment vented to outside the boat.
                        Terry
                        Br$keAweigh
                        1987 3270
                          Below is a portion of the ABYC rules on propane installations. I believe that the surveyor is referring to the sections in blue. Frankly, I personally share the surveyors opinion. I've never liked Bayliner's installations because the propane cannot flow directly overboard. On my boat I installed a propane locker with two tanks on the hardtop and eliminated the tank under the upper helm.
                          A-1.7.6.1 LPG cylinders, cylinder valves, regulating
                          equipment, and safety devices shall be readily accessible,
                          secured for sea conditions, and protected from the weather
                          and against mechanical damage, and shall be
                          A-1.7.6.1.1 installed in a ventilated location on the
                          exterior of the boat where escaping gases will flow directly
                          overboard, or,
                          A-1.7.6.1.2 if the escaping vapors will not flow directly
                          overboard, the cylinder shall be installed in a dedicated
                          locker meeting the requirements of A-1.8 LPG
                          LOCKERS.
                          A-1.8 LPG LOCKERS
                          A-1.8.1 Lockers used to contain LPG cylinders,
                          cylinder valves, regulating equipment and safety devices
                          shall be designed to minimize the likelihood of use as a
                          gear storage locker and shall be,
                          A-1.8.1.1 vapor tight to the hull interior, and
                          A-1.8.1.2 located above the waterline, and
                          A-1.8.1.3 constructed of, or lined with, corrosion
                          resistant materials, and
                          A-1.8.1.4 shall open only from the top with
                          A-1.8.1.5 a gasketed cover that shall latch tightly, and
                          A-1.8.1.6 shall be capable of being quickly and
                          conveniently opened without tools.
                          A-1.8.2 Installation:
                          A-1.8.2.1 LPG lockers shall be installed so that the
                          locker opens only directly to the outside atmosphere, and
                          A-1.8.2.2 If a LPG locker is installed inside a boat
                          locker, the LPG locker shall be located as high and as close
                          to the boat locker's opening as possible in order to comply
                          with A-1.8.2.1.
                          A-1.8.3 When means of access to the LPG
                          equipment locker or housing is open, the cylinder valves
                          shall be capable of being conveniently and quickly
                          operated, and the system pressure gauge dials shall be fully
                          visible.
                          A-1.8.4 Lockers shall be vented at the bottom by a
                          dedicated vent, with a minimum diameter of any
                          component in the vent system that shall be not less than 1/2
                          inch (12.5 mm) inside diameter.
                          A-1.8.5 Locker vents shall be led outboard, without
                          pockets, through the hull to a point lower than the locker
                          bottom and above the waterline with the boat in the static
                          floating position.
                          NOTE: See ABYC H-27, Seacocks, Thru-Hull
                          Connections and Drain Plugs, for requirements for
                          seacocks.
                          A-1.8.6 Locker vent openings shall be located at
                          least 20 inches (508 mm) from any hull opening to the boat
                          interior.
                          A-1.8.7 LPG lockers shall not be used for storage of
                          any equipment other than LPG cylinders, cylinder valves,
                          regulating equipment, and LPG safety devices. See A-
                          1.8.1.
                          A-1.8.8 Storage provisions for unconnected reserve
                          cylinders, filled or empty, shall be the same as for the
                          cylinder in use.
                          2013 Boston Whaler 130 SS
                          Isla Verde, PR
                            Leaked propane will travel directly towards the center of the earth. I thought about the flybridge too... but I think it would be dangerous.
                            I keep my tank on the swim step.
                            The other option, IMHO, is put it where you want to, but install a propane sensor alarm in bilge that is loud enough to annoy anyone nearby.
