I would measure this but am not at the boat - What do the air conditioning units draw each under steady state and what does the raw water pump aka "A/C Relay" draw? I working on my solar set up and I am thinking about moving all AC and heat to one 30A bus, sourcing everything else from the other bus powered by inverter. This approach will eliminate a transfer switch and/or reduce the requirement for a lot of pass-through current on the inverter/charger (= less $$) .
Not too worried about heaters as a) in south and b) likely will swap one aircon unit for a heat pump style
thanks in advance.
thanks in advance.
