Replace motor mounts on 3988...Hino 6 cyl.-gctid806138
    Is the motor mount replacement on a 3988 with Hino's a do it yourself job or best left to the pros. How tough is it, and what tools do you need.
    Pretty easy. Bottle Jack and something to spread the weight under the jack. Do one at a time. That assumes stringers are dry.
      Good News...Do I have to disconnect the prop shaft, or is there enough flex to lift the engine w/o damaging anything.
        Don't lift the engine. Just take weight off the thickness of paper and your shaft alignment will be fine.
