in my 3587 there is an aft bilge access right in front of the rear engine access panel. I am seeing some water in there. it's clear water.
it looks like this bilge channel runs under the bed to the rear of the boat. when I checked the rear access where the steering and trim tab gear is I don't see any water, not sure if the two are connected and might be the angle of the boat with water running forward.
I checked under the bed and I see no water in the area that is visible under the access in the bed. I see no water in the access panel that is port of the end of the bed. just noticing in that one small spot right under the holding tank. the water is clean so it's definitely not the holding tank.
I suspect fresh water tank that is located under the bed. above the bilge section.
So..
- Anyone had similar and have suggestions for where it's coming from?
-Any suggestions for other sources for this area other than the water tank- my boat is in fresh water so it's possible it's not the fresh water tank.
thoughts?
I think my next step is going to be to drain the tank and see if I get water, then fill to 1/4 nd recheck, then half and recheck etc.
So..
thoughts?
