I have two AC units, one is under the master cabin bed and the other is in a hatch under the lower helm. There is a raw water strainer under a hatch in the master cabin aft of the holding tank that I assume is at least for the fwd AC unit. The dashboard has 3 breakers for AC fwd, AC aft and AC relay.
Is the strainer really for both AC units or is there another strainer somewhere?
Is there a raw water pump for each AC unit somewhere else or is each AC unit fed from a pump on the AC skid?
Are there impellers (like the motors/genset) that need to be regularly replaced?
Thanks!!!!
Thanks!!!!
