Navigation lights-gctid397207
    I had to replace my navigation light switch in the upper helm. I must have done it wrong because now the lower helm switch will not control them. If someone gets some time for a look see could you tell me the colors of the wires going to which contact to the switch on the upper helm? There should be grey/w blue, blue/ w grey. I believe the grey is for the anchor light and the blue is for the nav lights. I'm just not sure which order they go.
    Info as to the model boat you have is always helpful.
    Jim McNeely
    Twin 5.7s with Bravo2 drives
    Brighton, Michigan USA
    MMSI # 367393410
      Sorry about that!
      I have a 1991 3288 motoryacht. Thanks for the heads up on the info. Upper helm is the switch I am having the trouble with. None of the lower helms wires got touched.
        Try the gray wire first, try each location, gray is the color for nav lights, be sure that you have the hot wire in the correct place.
        Gray with blue should be the anchor light. remember-the terminal on the switch is usually the oposite direction of the switch location.
