Removing Engine Room Floor 3870-gctid804459
    There is probably an obvious answer, but how do you remove the engine room floors (covered in diamond plate) so I can scrub them out? I'm just not seeing it and searching turned up nothing :blink:
    There are some flat head screws along the edges. Are you cleaning the diamondplate or going after the bilge? I've taken my pressure washer to part of mine and its waiting for me to finish the job.
      I'm going after the bilge :sick: And the diamond plate once its out, might as well. . .
      I see the screws, I'll mess with it and see if it comes up then. I just assumed that held down the diamond plate to plywood that would lift out, but I see no finger holes. What's under there? Wood cleats? Framing? Just a peice of plywood?
      thanks!
