After reading a comment on a recent post about a carbon monoxide fatality in the rear berth of a 32xx while under way. I decided to install a CO detector in the rear berth. I was wondering though how much of a problem it might be with the diesel engines as compared to gasoline engines. Has anybody ever used a CO meter to test this area while under way? We normally have the bilge blower running on Mr. Darcy while under way as the smoke alarm has sounded a time or two. Of course after discovering that one of the vent louvers was on backwards, and then reinstalling it correctly the problem went away. The engine compartment was actually being pressurized with both louvers scooping air. We still run the blower as a precaution. On long fishing trips someone will normally want to nap in the rear berth. Just curious about others experiences in this regard. The 38xx series also has a berth that shares a wall with the engine compartment.
Greg
Greg
