My thru hull vents for my sanitation tank are plugged up with salt and etc, so I replaced them this morning. In the process I noticed there is an inline sanitation tank filter on one of the hoses leading to one of the vents. I looked at replacing the filter as I am sure it is atleast 4 years old and discovered they are pretty expensive which leads me to wonder if I should eliminate the filter. Do they actually work and is it worth replacing?
Thanks. Jamie
Thanks. Jamie
