so my dads byliner has been sitting for a few years in salt water, noticing she's listing a little more to strb with even amounts of fuel in tanks, is there a known common problem of water getting into the fuel tank supports? is there foam in those voids? i also have another Q about the 18w430 generator, its putting out 120 volts up to the electrical components just before the hour meter, but then nothing to my panel in the salon, the part numbers are rubbed off, it seems to have a small manual reset next to hour meter, could any of these be the cause of no power to panel? as well as when its running theres a steel block behind the head that has what looks like a washer and a grommet on top, there is a little water and air coming out or looks like its boiling, any thoughts? new to this forum and have ALOT of questions before i bring this thing to florida haha.
91 3288 BAYLINER MOTORYACHT LISTING MORE TO STARBOARD-gctid803510
Not sure about your generators but there should be a switch on the main electric panel to select between shore power and generator.
I am also new to the forum but learned that 3288s tend to list to strbrd by default. In our boat the previous owner put 2 lead blocks of 25kg each down in the port locker (aft stateroom) to level the vessel..
_________________________________
HMS Yorkie
1990 Bayliner 3288
2x Hino 135 / Water Cooled Turbo
Antalya / Turkey
If you use the search function of the forum you'll find a lot of topics with TONS of suggestions, explanations etc. on lists...especially to starboard fyi.
Welcome
1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
