3288 potable water level sender unit-gctid803499
After reading the first post I was going to mention since you already have gone this far in your project that now might be a good time to examine your water tank. These things are notorious for leaks as many of us can tell you.
On tank I had baffles spot welded on the inside of the tank for sloshing while underway. The spot welds were stressed and let loose.
There are a few companies that make a good plastic replacement tank.
If you just want to go the sender route they sell several sizes on ebay.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
Put this one in my plastic tank and it has worked fine. They will need the depth of the tank when you order. http://www.wemausa.com/sensors/level...l#.WPGhk9QrLUI (SUS 316 Stainless Steel)
"Martini's Law"
Nova Scotia, Canada
I'm not sure of the brand or if it is original it was in the boat when I bought it. My 3288 is a 1995. Another thing you might think of is putting a clean out access port in the back half of the tank at the low spot. I put one in and was really surprised at what it looked like in there when I cut the hole. It also makes it real easy to empty the tank for winter storage. I can't show pictures as the boat is rapped for winter but I might be able to send some the end of the month. I live in Alaska and we still have plenty of snow in the interior. I don't remember seeing any writing on it but I can look again when I prep for summer.
1stshop, That sounds like a good idea for the winter layup. I bought a cheap endoscope from Light in the box online. I used it to try to see into my fuel tanks to help me determine if there was a sludge layer or if I could get a general idea of what shape the inside of the diesel tanks where in. I did get some decent views but I had no control over how to direct it. Now that I have access to the top of the tank I think I'll poke it in there and see what I can see. The aft access hole sounds like a very worthwhile idea.
1990 3288 twin 150 Hinos
previous: 1964 28' Owens express cruiser, v8 crusader
For a plastic tank I use the TechEdge sensor(s) that I am very happy with. I have the sensors on my black, gray and clean water tanks, all coming to a singe monitor.
http://www.rvautoparts.com/Tech-Edge...It0xoC-p_w_wcB
Good luck
[email protected]
[email protected]
