I am looking for some ideas to take the droop out of the cover and reduce the water pooling. I've experimented with various homemade ridge poles and bows but still not entirely satisfied. I'll be sewing a new cover soon and would like to prevent water from collecting on it. Twice during the recent windy, wet weather, I came out of the salon at the just in time to have 2-3 gallons of cold water poured down my neck. This probably only happens to me. :whistle: Thanks...................Dave
3288 upper helm cover-gctid802908
How about let it sag in the middle and leave a big hole? Keep a 5 gallon bucket under the hole, with a hose hooked to the bucket that drains overboard?
Just a thought that may or may not work.
Esteban
Huntington Beach, California
2018 Element 16
Depending on what your design is, I just had a new tarp sewn for the upper helm last year. In two places the guy put two brass eyes and supplied two small telescopic rods that the pointed tip of the rods go into. They are evenly spaced and run down the center front to back. This holds the cover up and tight once the cover is snapped all the way around and its sloped toward all 4 sides. He put a flap in the back of the tarp which covers the entrance to the helm so no wind problems. I wont have it on for a few days but would be happy to post some photo's if your still interested.
Dan
Frostbite Falls, Minnesota
Claudia V. III
1988 - 3218
Gas Drives
The cover needs to fit and be tight then you can use adj poles to put a peak in the cover so not to hold water.
1988 3270
135 hinos
Seldovia ALASKA
KEVINS UPHOLSTERY
KEVINSBOATTOPS.COM
Marine canvas/Upholstery
since 1975
I had "droop" issues with my Bimini on my 4588. As it was a perpetual problem,I figured out a way to install bows in between the ss cross tubes of the Bimini.
I bought 3/4 inch pvc pipe and tees. I cut 1/2 the tube side of the tee to create a "C" shape along the tube, so when the pipe was in stalled into the single exit of the tee the "C" would sit onto the ss rail. I cut the pipe a bit longer than the distance between the s rails and inserted them into the cut tees. I then snapped the "c" shapes onto the rails so the pipes were perpendicular to the rails. The "C" cut tees in concert with the overlength pipes allows the pvc pipes to bow under the canvas and create a durable solution for the droop. You can install however you need to attain the bow you want. It worked great for years and was SUPER cheap to do.
I hope this helps.
Happy boating,
BJ
OMEGA
5788
BJ
OMEGA
5788
My previous boat was a 1989, 2858. The flybridge was about the same size as that on a 32xx. I used a pole with support straps similar to this one. It held up to rain and some snow:
http://boatsuppliesplus.com/product/...upport-system/
If I were to do it again, I would use one of these:
http://www.go2marine.com/product/112...port-pole.html
2013 Boston Whaler 130 SS
Isla Verde, PR
