This is a set of tunnels that I will be sending to a BOC member, I erred in the lay-up and he ended up with 1 extra layer, but at no charge-total 1/2", all that is needed is 3/8", which is what my set ended up as; as well as set #3 which is committed, I will be leaving for Alaska on May 12 and when I get back at the end of Sept. weather temps permitting I will make a few more.
I like helping people as well as BOC members, I do not need the money, but a little extra always allows me to support my 3870 in Alaska.
At 72 I still need to keep busy, not time to lay down and sit on the couch yet.
The weather temps kept me from building more, at 80+ deg the resin kicks off to fast.
I lost a gel coat spray gun due to temps.
The buyer of the first set intends to record the difference in performance, the member has a 18" long set, I think that 16" will work, but one can always cut 2" off, the resin is ISO type, as well as the gel coat.
Pat: boatworkfl
Pat: boatworkfl
