I have some spider web cracking of the gel coat and wondered if there is a good fix for them ????
Solution for spider web cracking of gelcoat ????-gctid802708
A good GRP guy will redo with new gelcoat, and you will be amazed. Machine sanded back, new gel applied, probably by roller, then sanded, buffed and polished.
A lifetime of racing everything from dinghies to world girdlers, but one of those lucky people who just love being afloat. So .... when the body doesn't work like before, it doesn't mean staying ashore.
Blustery Day
Bayliner 3288 Motoryacht, 1991.
Twin Hino 150hp diesels.
Purchased 23 February 2017
I have some spider web cracking here and there. I'm going to try Capt Tolleys. It's supposed to be good for that kind of repair. I have no first hand experience yet.
MV Kia Orana
Currently Enjoying the PNW
[quote]I have not used this but wondered if it works[quote]
I've tried this stuff and found it to be so-so. I would suggest that it's best used in inconspicuous areas, and certainly not on an open shiny panel.
The old story, if something looks too good to be true...................etc.
Rob
Bayliner 5788
'Merlin V'
Vancouver BC
Spider web cracking can be the result of primarily a couple of things. One is obvious, a mild collision with something or overstressing. Another is excessive force used when pulling the part from the mold. Both normally involve at the very least the fiberglass mat laid up against the gelcoat. Sometimes it goes deeper. The boss used to have us sand and buff, they always came back. Then he had us grind away the gelcoat and spray on new gelcoat, sand and buff, the cracks eventually came back. Finally we took it as far into the lamination as necessary to get to an undisturbed laminate layer. Repair the lamination, gelcoat, sand and polish, cracks never came back. Just a little history of lessons learned.
Greg
Newport, Oregon
South Beach Marina
Greg you are on the money, for slight cracks I Dremel them out and fill with bits of glass and resin mixed with cab. then sand flat a bid down and overlay with minimum of 2 layers of Vail --- very thin fiberglass mat. This would work on dashes that are cracking from the heat than the cam be finished with lighter colored Gel Coat, one thing with cracks going to hardware location, pull the hardware since in most cases that is where it started.
