My sink fell down in my 47 and is not supported by several plastic cups
Although that'll work but I'll have to buy more cups I'd prefer to fix it.
There are supports on all corners of the sink that have come down with the sink and taken the granite with it (chunks of granite stuck to the granite). I'm sure I could scrape all surfaces clean and put a good bead of silicone and put it back up but am I going to have the same problem again? What have others done when this happened? I know that putting some support poles under the sink would give it lots of strength but then I'd have poles hanging down blocking towel storage etc. Are there other glues that are stronger and more effective than silicone?
Thank you!
Derek
Thank you!
Derek
