Last fall before I winterized the boat my hot water heater was working fine. When I re-filled it and turned it on the other day it is not working.
It is a Seaward S-1800 which is an 18 gallon tank. It is 16 years old so maybe it is time to replace it anyway. Could it just need a new heating element?
It is not heating water in the tank using the breaker panel. Tomorrow I am launching and testing all systems. I am sure hot water will be produced from the engine flow through.
North Harbor Diesel will take a look at it sometime soon to diagnose. If I do have to replace it are there recommendations from the Bayliner gang?
Thanks,
Jerome
Thanks,
Jerome
