What model of Sherwood Pump do I have?-gctid801976
"The Other Gary" post=801978 wrote:
Sherwood 17000
Order a pair of K models with the remover for your first order. The threaded remover is a big asset.
Do you know if that thread is a standard machine thread? I tried 1/2" NPT (thinking I would make my own tool out of a nipple and Tee) but didn't fit. I am going to try 18mm and 3/4" bolts to see if they fit, otherwise I will try to chase down a proper puller.
Something for future consideration the next time you are ready to replace impellers is to upgrade the pumps to a Seaboard Marine SMX pump.
http://www.sbmar.com/product/smx-1730-seawater-pump/
The Sherwood pumps are very prone to failure (yes, I have experience) and the SMX corrects the design defects of the Sherwood. People that have upgraded have been very happy with the change (me included)
In the case of my Sherwood failure, the inner part of the impeller shaft has a groove machined into it for a snap ring, which creates a weak point for the shaft where it will shear off. Once this happens, you lose your water flow...
Pat
Paragon
1999 4788
