Looking for a "pro" to re-do a fly bridge deck patch. I'm in Channel Islands.
My 4588 fly bridge had a table base mount portside rear of settee. Base was rotted corroded and determine as a leak point to the salon. Removed table base & found the
Deck coring saturated & mush. Tech cut out the affected area, cleaned and dried. Filled with foam and glassed as a temp fix with the intent to finish after storm.
The top coat of Interlux never set properly and the patch 22x18" although functionally preventing leak needs to be done properly.
So looking for a "pro" in Channel Islands area.
