Our 1995 4788 windows look... old, faded and need love. Has anyone painted or redone theirs?
Motoryacht aluminum widow frames-gctid800871
Yes. You have to scrape and sand them down very well. Have to get all the aluminum corrosion off -- particularly where it bubbles and pits. It's important to get on a good coat of Aluminum Primer -- there are several brands out there but I understand something with Zinc Chromate works best. You can then either brush or spray -- brushing can leave streaks but spraying can be tricky so I'd leave that one up to you.
Terry
1999 Bayliner 3388
Twin Cummins 4BTA
Fisherman, Cruiser, Boaticus-enthusiasticus-maximus
Member Royal Victoria Yacht Club
This old chestnut has been a regular topic ever since I joined BOC many years ago. Uncle Bob is correct about carefully preparing the surface and coating all bare aluminum with zinc chromate, otherwise you'll be doing the whole thing again sooner than you'd like to.
One additional observation, since repainting the frames on our 3258 back in 2002, the the surface of the corroded area (usually around the drainage slots) will likely need an aluminum filler, as the pitting is often too deep to sand it out smooth enough for a good finish.
I have a friend with a 2008 490 where the frames corroded and paint bubbled before the boat was two years old. The authorized factory warranty fix demanded that the drainage slots be ground out wide enough that no water would be trapped behind them. As the 490 window frames are powder coated white, the wider slots would typically be very noticeable, but the repairer removed the frames, re-anodized them after repair, then powder coated them again - an excellent fix, but why did Bayliner/Meridian let this become a legacy problem with most of their motor yachts for all the years before bonded in windows became the standard?
Rob
Bayliner 5788
'Merlin V'
Vancouver BC
On the 32xx series, window frames can't be taken out. That's all that's holding the flybridge on. They fixed that design error with the 33xx.
Esteban
Huntington Beach, California
2018 Element 16
What is a bonded in window?
Rob
Bayliner 5788
'Merlin V'
Vancouver BC
