So I have a 1994 4788. Just finished up phase one. Electronics install, plus full service of both Hino's. We splashed last week. Now in slip in Anacortes WA. I went with full package of Raymarine electronics. Took down open array. Went to a Radome 24inch. New hole in thicken section off arch. When drilling wood came out like mush! Very wet, dark crap. It is a hinged arch, with standard factory stuff above. Now mostly removed. Is it worth the rebuild? Or do I consider an aluminum arch. Who done either, Input would be great thanks
What to do about 4788 arch.-gctid800394
I'd start with a call to Boaters' Discount to see what they have for a replacement: http://www.boatersdiscountcenter.com/index.htm
I've always said that if I EVER have a real Arch problem, I'm going with an Aluminum arc.
I bought one from an outfir called "Atlantic Towers for our old 2452 years ago and it is onbe Nice looking arch, and easy to install1
4788 DOS PECES - SEWARD ALASKA
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
You might want to drill some exploratory holes in other parts of the arch to see how far the rot extends. It is possible/likely that it is fairly confined to the failed penetration (presumably the previous radar installation). With luck you may only have a section to fill.
Alan Teed
MOONSHADOW
1996 Wendon Sky Lounge 72'
Gig Harbor, WA
Previously:
1994 Bayliner 4788
2006 Hylas 49' SY
Bayliner 2855
1977 Cal 34' SY
1981 Hunter 33' SY
We have the same problem on our 45, so I purchased an arch from Atlantic Towers. I have it in my warehouse and am planning on installing later this month. I can tell you the quality of construction is excellent, the price was certainly right @ $1899 delivered to Seattle, and it includes everything you will need for the basic install. They have a lot of add-ons available you can buy as well if you want to customize it some. The one main advantage with changing out the waterlogged arch for the aluminum one is getting rid of about 500# of excess weight. The only possible downside that I can see is that while the aluminum tower may make the roll in a beam sea a bit less, it may also be somewhat quicker.
I am going to repair it. Very small section is damaged. Just top center. It has been a pain to work on. It is hinged for one thing. Screws stripped easy. Trim molding isn't in great shape either. I will up grade lights inside LED maybe color changing type. New speakers as well. Thanks all.
jim and Anna 1994 4788 Refresh 310 Hinos
Jim
Here are some photos of our install. We are just now doing the wiring for the electronics but you can see how the arch was removed and installs. We cut the old arch into small pieces with a sawzall to make the disposal a bit easier, then patched the dozen mounting holes with chopped fiberglass and faired with marine catalyzed putty. we then color matched the repair with two part urethane. That was day one. on day two we did the install of the new arch which took us about 4 hours. (lots of fun with the wind blowing 40 kts) I will send more photos when the wiring of the electronics is completed later this week.
