hi any one know where i can get replacement window seals for a 1983 3870, thanks
3870 salon window seals-gctid799991
Hi there,
I went to the dealer here in Bellingham and picked some up, it's called window flocking, the galley and Midcabin windows take the smaller size than the larger cabin windows.
Good luck
{Living our Dream}
John & Nancy
1988 Bayliner 38
175 Hinos 8.5 kw Westerbeke
Sandy Point Ferndale Washington
Welcome. Which seals are you asking about? Trouble is, you could be meaning the ones that hold the glass in the fixed or sliding sections of the side glass or possibly the seals that hold the front windows glass in. A picture would really help. If you are asking about the fuzzy channels that the sliding side glass ride in, that Masterman called flocking, can be considered a seal, may be a different answer.
I'm not trying to be difficult, it's just that you know what you mean, but I'm a little slow in picking it up. Also, knowing where you live and/or keep your boat may help direct you to a local to you supplier.
I believe this thread will help you find what you're looking for.
Derek
http://baylinerownersclub.org/index....acement#696451
1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
I just ordered replacements from Amazon via DK.
The shipping was less thru Amazon. There is a thread on this issue that details the dimensions of the side wall & width of the flocked slide track. The removal and installation is simple and detailed in the thread. Make sure to do the drain slots!
Jim Mason
1990 4588
Channel Isl Harbor, Ca
