Hi all. So we took her out last night and about 20 mins out the nav lights went out. I took out the flashlight to check fuses and noticed a couple blown. While I was removing them to check the size I noticed the nav lights came back on. Then they turned back off after about 10 mins and won't turn back on.
I replaced the blown fuses and checked the bulbs but still no go. I am checking the fuses under both the top and bottom helms. Anyone have any ideas what is going on?
Thanks!
Thanks!
