Just noticed that the transmission cooler for Hurth 630A has started leaking. I can see that it has a brand on it but is illegible. Not sure where the original part comes from. Hoping to get advice thanks. Hugh
3888 Hurth Transmission Cooler-gctid396096
Started boating 1965
Based on information from this site, I ordered new coolers from Lenco - I believe they were O.E.M. http://www.lencocoolers.com/ . They were good to work with and shipped promptly. Fisheries Supply in Seattle also stocks coolers. If one is leaking, they are older than 7 - 8 years and used in salt water it's time to replace both of them. Good luck. Rick
Rick
2002, 3788
I found this one but which looks similar and very similars specs but I will check with them to see if it will do the job. Has anyone used these?
http://marineengineparts.com/shopsite_sc/store/html/product97.html
Hugh
1990 3888
Hino 175 Diesels
Hugh
Hugh
1990 3888
Hino 175 Diesels
