The port tachometer works intermittently. I noticed that the sending unit was not screwed on tightly. Could this be the problem? Unable to tighten it because I don't have the correct tools.
Tachometer problem 210 hp Hino-gctid395418
first ck your plug at the eng, between harness and eng, my problem was there.
its ok to have a loose sending unit,(IMO) there is a small plastic shaft between the sending unit and the eng, if it is broken no tac,
1988 3270
135 hinos
Seldovia ALASKA
KEVINS UPHOLSTERY
KEVINSBOATTOPS.COM
Marine canvas/Upholstery
since 1975
