New venturi windscreen for 3870-gctid786203
    I picked up my new venturi from Boaters Discount and will do the install when the weather is milder.
    The rubber / foam gasket material under the old venturi is cracked, torn, and disintegrating.....Boaters Discount could not recommend
    what to install as gasket material.
    I think several of you have done this project......what did you use and what could you recommend?
    Allan
    1986 - 3870
    175 Hinos
    Moored in Ladysmith BC
    Mine has no gasket.
    Nobody gets out alive.
      how about some extra railing protection?
        Mine didn't have any gasket.
        Sean
        1987 3870
        Crimson Pride II
        Past Commodore Mukilteo Yacht Club
        MMSI: 338080226
          Only Clear RTV on mine when removed...
            Ruffryder....i am planning on a 1" railing just above and forward of the venturi to relieve the strain of the forward canvas on the venturi, especially in strong winds
            Allan
            1986 - 3870
            175 Hinos
              my 3870 has the ss railing toke the venturi off. all it did was collect bugs
              1984 3870 bayliner
                When it's done right, your venturi will be very well protected and possibly be able to replace the damaged section only...
                  Old crow did you order the ss rail or bend it yourself? Pics?
                    Can I ask what you paid. I was not aware Boaters was selling them.
                      Sent you a private message
                      Allan
                      1986 - 3870
                      175 Hinos
                        Can you send me the info.I'm looking to do the same. Just don't know where to buy the stuff.
                        Thanks Kevin
                          Kevin
                          Boaters Discount Center
                          La Conner Washington
                          Ph 1 800 488-0245
                          Allan
                          1986 - 3870
                          175 Hinos
                            Mommaboyd
                            Came with boat will post pic in the spring
                            1984 3870 bayliner
