Hi all,
I've got a friend with a 2005 341 Meridian (twin Cummings) and he gets steam coming out of the upper exhaust on the port side when running about 1500 RPM. It doesn't seem to steam at idle and doesn't seem to steam at 2500 RPM. The starboard side doesn't seem to steam at any RPM.
The 341 has dual exhausts on each side. The primary exhaust is underwater and the upper exhaust is an idle bypass so the engine doesn't see the backpressure of the underwater exhaust when starting.
Engine temps are normal and he's just had the impeller changed and the minicooler cleaned so it doesn't look like a lower water flow issue.
Has anyone seen this before? Any suggestions?
Thanks,
Jim V.
Thanks,
Jim V.
