PLEASE HELP SUPPORT OUR SITE
I think it is normal for the pressure to increase once you bring the ROPS up. Mine run at around 70 while under load. It is not unusual to see them lower at Idle. But yours do sound low. What is your idle ROP? is it set low? also are you sure you have the duel helm senders?
I would think an oil pressure over 40 PSI on either engine would be great. Having a different reading on one versus the other is pretty normal from what I have seen on Hinos. Only thing I would worry about if if I had gotten diesel into the oil due to a bad injector which would reduce the viscosity of the oil and pressure on that engine. If your readings do not change after changing oil, I would expect you are good to go.
Started boating 1965
