EH700 Raw Water Impeller Option?-gctid776130
    I see that there is a Sierra option for the four cylinder Hino, but just a Jabsco for the six listed in the database, which btw, is absolutely awesome. I've done a search on the EH700 impeller and learned a lot of nuances, but no luck there either. I tried several google searches and failed again. I have nothing against Jabsco, but the comment about Sierra providing the complete kit on the fours where the Jabsco does not is an important difference considering the quality is usually comparable between the two companies.
    Is there a Sierra option?
    1988 3818 "GLAUBEN
    Hi Pete,
    I did a rebuild on my OE Kashiyama pumps this year.
    Parts are a little hard to come by.
    Pump model is a Kashiyama 1690-1659R
    Impellers: Jabsco 31130-0061
    Kashiyama SP-130
    Hino 16131-1350
    DJ pumps (Austrailia) 09-42-1001
    Mercruiser 47-831311350
    I went with the Jabsco as they are off the shelf with a local supplier.
    All these numbers are for the same impeller so you may be able to use them to cross reference to a Sierra product.
    Good source for other US marine and Kashiyama parts are "The Anchorage" in Canada.
    Ian B)
    Ian & Emma
    MV "LaPaloma"
    1990 4588
    Hauraki Gulf
    Auckland
    New Zealand
      Thanks Ian. In my search I found all of those and a few from China. My default will be the Jabsco. I live 25 miles north of Seattle so I'm in a "parts rich" environment. The previous owner left some new spares aboard and i thought I had the part numbers of those on my phone, along with the fuel and oil filters that are there. Yeah, well that's a do over next time I go to the boat.
      1988 3818 "GLAUBEN
        There is a Jabsco distributor in Ballard. If you have a business license, you can sometimes get a deep discount.
        Started boating 1965
          I can supply a rebuild kit for these pumps with new water seals, lip seal, impeller, and bearings. These can be fitted with no machining or adaption of the pump body and allows you to keep your original pump. I understand the major problem with these pumps is the water seal is now obsolete rendering the whole pump obsolete if it is leaking from the shaft seal. You can contact me at kiwimarineservices@xtra.co.nz for more details. You can get your engineer to install the kit or you can easily do it yourself if you do your own maintenance. The kit and installation is a fraction of the cost of trying to adapt an aftermarket pump to fit the engine or doing expensive machining to adapt another type of water seal.
