4588 Bimini hardware needed-gctid393523
    Measure out the tubing, then source some stock in the same size. Your local tube bender should be able to match the bends...
    Guest started a topic 4588 Bimini hardware needed-gctid393523
    Hi, we had high winds which bent the main(longest) support for the Bimini beyond repair. All the other parts are ok. Anyone know where I could buy a replacement? I have worn google out with no results. Thanks in advance for any help.
