Hi All! Anyone know where to find the compressor wheel for my 89' 32xx hino IHI turbo? Thanks
Help find a Hino 4cyl 32xx turbo compressor wheel-gctid393145
North Harbor is likely to only have complete turbos at several thousand dollars. Talk to the folks at Alamo in Kent, Wa or just East of Vancouver, BC. They came up with parts for my IHI and rebuilt it when two other companies said no parts were possible for the turbo on my 310 Hinos. The main part needed was the same as yours. Apparently some IHI turbos use same compressor wheel but with different part numbers that vary with turbo part number.
Started boating 1965
Bayliners owned: 26 Victoria, 28 Bounty, 32, 38, and 47 since 1996Comment
I have a good used turbo for a 32 for a parts turbo, the exhaust housing is cracked and wont hold water. Email me at [email protected] or call 386 383 1872 and see if you want it.. Earl International
